Can anyone recommend an airplay compatible projector that works well in moderate light? thanks
trying again…kids are restless
Getting an appleTV to hook up to a projector of your choice would open up more options if that’s do-able?
Don’t know about specific units but the photography club I’m a member of has used BenQ, JVC and I think the current one is a Sony all of which have been pretty respectable in terms of image quality. (none of the ones we had were airplay compatible though).
Don’t think any of them are that good unless you’ve got the lights off and curtains closed though.
It’s difficult to quantify what you might consider to be “moderate light” though!
