I just received my 2020 iMac with the Nano-texture display and set it up side-by-side with my current 2017 iMac.
The decreased sharpness of the nano-texture panel is āinsaneā and I am shocked at how little you hear about this⦠I have heard some people say, āoh itās a little bit softer when you are looking at white text on a black background but you get used to itā, etc. But the difference is so stark that it doesnāt feel like itās a 5K or even a 4K display.
The glare reduction is amazing, and the screen does have a āmagicalā look to it because of it, but the softness is potentially intolerable.
I work primarily with graphics that go to print and my display faces two big windows which honestly did present glare issues while I was working ā but now the softness is its own issueā¦
Itās very difficult to take pictures of the difference with an iPhone camera so I will be taking some w/ a DSLR and adding them to this post.
Very disappointing, I might even return the iMac and get the same config without the nano-texture⦠Going to sleep on itā¦
Maybe I should have known better and went to see the displays at the store first, but, you know: the virus, different lighting, different settings, etc. so I thought it would be too hard to see side by side.
For anyone thinking of getting the nano-texture, sadly: buyer beware. Definitely go see it in person first.
Here are two links to high-res photos (1/20s exposure time, f/8, ISO 100, on a tripod) I took of the full screens. Semi-empty desktops with the same wallpaper, both displays on same stock iMac color profile:
(Will continue to edit my post and add more images as I take them, just wanted to put this up there quickly ā these were taken with a DSLR manually-focused to be as tack-sharp as I could get in each picture)
