Charger for Mid2009 MBP 17 - MC226LL/A aka A1297 4pin t-shaped
Please – and thank you!
Welcome to the forum. I’m not sure what the purpose of this post is, though — are you looking to find/buy the charger you’ve listed?
Looking to buy a cheap version of this
I have to say, when I needed a charger for an old MacBook several years back, I just went and bought a third-party charger on eBay for like $15. Worked fine. It’s far enough ago that I can’t find it in my eBay purchase history, so don’t have a vendor to suggest - but those companies change names so often it probably wouldn’t matter anyway.
Still looking to find a charger for MBP 17 2009
MC226LL/A
Model# A1297
85W – T-Tip
eBay has a ton of them. You do not need a t-tip - an l-tip is fine.
