I’m going to buy some new charging bricks. I have a bunch of cables that are usbc and usba , my kids have iPads and I’m looking for something to charge an iPad and use both cables. Can anyone recommend one? I saw some no name ones on Amazon that have great reviews, some of them have more than two ports.
I guess I’m also trying to justify buying them. They’re not that expensive. But do I need them? Seems like everything is being charged by USBC now.
For wall chargers, I’m a big fan of the Anker Nano II. 2x USB-C, 1x USB-A, 65W total output. Because I have a few things which, despite having USB-C ports for charging, will only charge on a USB-A port (using at USB-A to USB-C cable).
When I’m out of the house and size/weight isn’t a concern, this Anker power block. FAA-compliant, 2 built-in USB-C cables, one USB-C port and one USB-A. It’ll charge everything I own, including my Thinkpad.
If weight/size is an issue, I have an Anker PowerCore III. 1x USB-C and 1xUSB-A, plus wireless charging.
I don’t mess around with “no name” items here because the consequences of something being poorly constructed or using uncertified/shady components are dangerous.
Some multi-port adaptors will only give full power on one port when more than one port is used.
Don’t necessarily shy aways from designs with legacy USB-A charging ports especially when you already have boat-loads of cables that go from USB-A to whatever else you need (i.e. legacy lightning or micro-usb or USB-C) or especially when you have (legacy) devices that require USB-A to charge.
Decide whether you want the wall-socket prongs to be permanent or retractable. Some chargers with retractable prongs are less stable (more fragile) than others. But of course no one wants to carry a non-retractable prong charger that could poke a hole in the pouch inside their travel bag.
On a related note, I like using a bunch of these to actually see what is happening with USB-C charging.
They are very inexpensive, and the tiny indicator will change as a device finishes charging.
Maybe it is placebo effect, but It sure seems to reassure me that a device is connected and charging more than the built-in indicator in the ipad or phone or other device itself.
I have used a MINIX charger for travel for several years, both domestically and one trip to London. It has worked great. I got it because of a recommendation on the Cortex podcast, where one of the hosts (Grey, I think) said they has used one for many trips. This made me confident in its reliability and safety.
Other than that, I would only go with Apple, Anker, or Belkin chargers. Cheaper ones often skimp on parts; I think David has put up posts or links about scary fire hazard assemblies. A family in our town lost their house because a cheap charger caught on fire. Super-rare? Probably. But super-catastrophic.
