I recently started having problems logging into https://talk.macpowerusers.com/ , when I use Chrome and 1PW, on iOS. The only way I could log in is to manually paste my credentials from 1PW into the login dialog.
I’m now having the same problems on two other sites, and have had a lengthy discusssion with the support staff at AgileBits. AgileBits said that the fix has to come from the Chrome developers.
It looks like I’ll be stuck with using Safari until this issue gets resolved.
I just hope Safari on iOS isn’t as problematic as it is on MacOS.
I’m curious if others are having login problems on iOS, with https://talk.macpowerusers.com/ on Chrome, using 1 PW, or other sites too.
I logged in last night using Chrome and 1PW – and, just to be sure, I just logged out and back in and all worked fine: 1PW entered the credentials and here I am.
Chrome Version 68.0.3440.75 (Official Build) (64-bit) but a new update is downloading…
I used to save logins to Chrome as well but I turned it off after reading about a bug/feature of integrated browser login managers like Chrome that allows users to be tracked by ad companies (but not by 3rd-party password managers like 1P):
