Cleaning IPad Magic Keyboard
My t and i keys on my iPad Magic Keyboard are not making contact consistently. I have used compressed year, a keyboard vacuum and cleaned around the keys with a AirPods cleaner. The only thing left is prying of the keys to clean underneath and I have not had good luck with this in the past. I do not want to replace with a 3rd party keyboard and I don’t want to purchase a new Magic Keyboard before I upgrade my current iPad (IPad Air 4th generation). Suggestions?
Do you have by chance a Apple Store in the vicinity?
They helped a friend of me with a problem that sounded similar.
Unfortunately, no—thanks, tho
Found this and it worked quite well: How to clean the keyboard of your MacBook or MacBook Pro - Apple Support
It’s specifically for laptop keyboards, but the angling worked well for the iPad Magic keyboard.
