Hi everyone, is anybody using a utility app that allows them to access LLMs like ChatPT and Claude from a right-click? I’m looking for one with Ollama and Azure OpenAI support for privacy, but if there’s one with a good UI I can always beg the developer for such an option.
I’m not looking for one that bundles in ChatGPT or similar for a montly fee, as it seems contrary to that business model to add such a feature.
Thanks!
This list should have it covered:
Thanks! I found this on reddit, and came up with AnySelect and Intellibar. In theory, AnySelect allows use of Azure OpenAI, but I could not get my credentials to work (though the work in other apps). I write the dev of that app and Intellibar.
I also found FridayGPT, which seems promising but has no trial and limited info available.
Just in case anyone else comes across this, the most promising option I have found is to use Better Touch Tool (of course), which already has a workflow to perform an action on clipboard contents.
