Because I have no experience with coding or programming (are those the same?), creating shortcuts with the Shortcuts app has been well beyond my technical abilities. But with Claude’s help, I was able to create a very simple shortcut that generates a blog template. I share this not because I created the shortcut, but to make the point that AI will enable many people to do things with their computers that would otherwise be beyond them.
I did the same a while ago with creating a variable packing list with options using Claude, and created some shortcuts to doing some things manually Vibe coding - Second thoughts
e.g. if I plan to travel internationally, I need to pack my passport, if my wife is travelling with me, I need chargers for her devices.
Before I did this, I loaded Taskpaper into OmniFocus and deleted the groups of tasks I didn’t need.
Claude made some things up which I had to question it about, but we got there eventually.
I took a simpler approach, one list for domestic travel, another for international. There is not that much difference in my case; mainly documents and international chargers, snacks (for 14" hour flights, and more cloths.
I now use Claude Code regularly to write Bash and Python scripts to help me get things done. An example: I was using Permute to join and transcode an enormous library of media files one by one. As a project, it was a nice-to-have, but not worth the investment of time and attention. I explained what I wanted done to Claude, gave it the necessary permissions, and I now have a Bash script that uses ffmpeg to chug through the project in the background while I do other things. Now that Claude Code is a tab in the Claude desktop app, it’s accessible to anyone who’s not comfortable working at the command line.
I did learn the basics of programming 40 years ago when I was getting my MBA (including Assembly of all things) and have no doubt that I could develop enough proficiency to do this myself, but why? I’ve taken a look at the actuarial tables and have decided I’d rather squander my remaining neurons on other things.
I’m not sure what Claude does – I use ChatGPT – but one of the downsides with Shortcuts is that it can’t provide you with the actual shortcut, even though it “thinks,” that it can; only pseudo-code on the action steps required. Additionally, in my experience, ChatGPT hallucinates quite badly on available actions/parameters available within Shortcuts.
Having said that, I’ve learnt a lot on Shortcuts from ChatGPT. But again, that’s “learnt,” opposed to outsourced to it to do the actual work. So, yes, it can be helpful – my longest shortcut is now 132 steps! – but compared to the ease with which it can knock up, say, JavaScript or AppleScript for the low level stuff I’m doing, it’s all a bit clunky when it comes to Shortcuts. As I say, just my experience.
