I am looking for a software that lets me press a keyboard key on a Mac and cycle between the currently open apps one at a time.
For example if I have Safari, Mail and Notes open with Mail as the active app, pressing the key should bring up say, Safari. Pressing the same key again should bring up Notes, then Mail on the next press of the same key and so on…
I am aware of the cmd+tab to bring up application switcher but trying to reduce the finger strain that comes with keeping the cmd key pressed down while pressing the tab.
Atm, I am using BetterTouchTool to have 4 on the numpad (am using an external keyboard) to press cmd+tab. The problem with this is that I can only switch between two apps - the current one and the previous one.
This Hammerspoon script should do it. Once all the apps you want to cycle are launched, the switch is low latency.
hs.hotkey.bindSpec(
{{"ctrl","alt"}, "c"},
function()
focusedApplication = hs.window.focusedWindow():application()
if focusedApplication:title() == "Pages" then
hs.application.launchOrFocus("Numbers")
elseif focusedApplication:title() == "Numbers" then
hs.application.launchOrFocus("Keynote")
elseif focusedApplication:title() == "Keynote" then
hs.application.launchOrFocus("Pages")
else
end
end
Gotcha. I ran into an issue grabbing the current apps dynamically, but if you don’t mind listing what you use in the applications variable, this will cycle through whatever’s currently open from that list.
hs.hotkey.bindSpec(
function()
applications = {'Pages','Numbers','Safari','Terminal','Reeder','Messages','Photoshop','DEVONthink 3','Spark','Keynote'}
applicationsLastIndex = #applications
currentApplication = focusedApplication:title()
currentApplicationIndex = 1
isAppSwitched = false
for i,v in ipairs(applications) do
if v == currentApplication then
currentApplicationIndex = i
break
end
end
-- Search applications array after currently focused app
if i > currentApplicationIndex then
applicationSearchResult = hs.application.get(v)
if applicationSearchResult ~= nil then
print(currentApplication,v)
hs.application.launchOrFocus(v)
isAppSwitched = true
break
end
end
end
-- Search applications array before currently focused app if needed
if isAppSwitched == false then
if i < currentApplicationIndex then
break
end
end
end
end
end
