What are the best options to deduplicate files/photos? Is there a rock solid recommendation for both files and photos?
As I’ve been rationalizing my spend on cloud storage, what I’ve come to realize is that I have instances where the exact file sits in many folders. Ideally, I’d like to simplify the folder structure, while removing duplicate files and empty folders to reduce clutter.
I’m also hoping that a file dedup can analyze beyond file name (there are lots of 'FINAL - FINAL3 type of docs) and do a solid comparison of the contents to suggest deletion.
With “All Files” and “Library” enabled in addition:
16.94 GB
THAT was enough to get me to do a one-time payment.
@rob I agree—huge savings! I use applesauce (and before that afsctool) to compress a bunch of stuff, mostly my /Applications folder and have it running on a daemon. I also do spring cleaning where I apply it to high-churn subfolders in my home folder. I have it hooked up to a ContexetMenu Action so I can right click any file or folder and transparently compress it. It does make a migration to a new Mac take longer though because of all the decompression/compression that is required.
