I am working learning both of these software applications now and was curious if anybody is using both for specific applications?
I just happened to pick Twitter feeds for my first entry into Devonthink and spent a few hours until I went to Devonthink’s forum and discovered that Twitter functionality was negated by Twitter in May 2020.
I am still in early days in exploring both of these apps and I know DT has a big following here at MPU I am wondering if there are any advantages using Eagle Filer.
Any inputs of view points would be greatly appreciated.
Tried DT v2 for several years but gave it up for a “low-tech” plain text, PDF, and Finder approach. That worked ok but I’ve found that EagleFiler elevates my workflow. It brings in email as a first class citizen and is in many ways a better Finder than Finder. But it’s nice to have two Finder-type apps. I use both in different ways. I love to read the excellent EagleFiler manual or browse the EagleFiler forum as I’m always finding a new way to do something. EagleFiler is a mature, deeply-designed, app that always feels solid.
I’m unclear from your earlier post – do you still use DevonThink? Sounds like no; when you refer to having two Finder-type apps you mean EagleFiler and Finder itself?
I use then used dt3 but find it to massive. Then lately they had an update and I lost a bunch of files and images.
So I went and bought EF and love it. Prior I just used the trial.
Now I find I use EF on the Mac and files on the iPhone and iPad.
When I do serious stuff I use the Mac. When I review or need instant view of something I just pop on the iPhone or iPad and go to files and can see everything in EF.
