There is a particular radio show that I want to listen to. I usually go into Overcast to find it, but this particular episode is nowhere to be found - neither in Podcasts.app.
I can listen to it online on the site through their native player, but not anywhere else. Does anyone know of a way to download audio from such a player on a website through an iPad Pro?
links to episode 90. Replacing the 90 with another episode (I only tried 89) seems to download/access other episodes.
I opened the link on Safari on the iPad and it started playing. Then I selected “Save in Dropbox” and it stored it as MP3. Now I have a copy of the podcast in Dropbox and can take it from there. Export? Open With?
There are a few tools that will show you the source code. I had one before, and it stopped being supported at some new iOS version. I currently have Sourcery installed, but the most recent update was October 2014. Still works though, but I’m worried about it’s future.
Search the AppStore for “source code reader” and you will find quite a few options. This might be my cue to replace Sourcery too
EDIT: A little bit of searching led me to discover that Textastic 7 can be used as well. This is my preferred code editor, so I already had it installed. For any page in Safari, change the URL from “http://” or “https://” to “textastic://” and the page will be loaded in a proper editor.
