I started to do a lot of web clipping to paginated pdf for offline reading. I am looking for a good app to do web clipping but have not found one yet
I compared DT3 and Eaglefiler, both have different degree of success. I guess web site with a lot of scripting may be hard to captured, such as this one (paywalled, with different content on scrolling ).
Both companies need to overhaul their clippers so that they capture the currently rendered content, rather than making fresh requests. I know that Devon has received this feature request a few times and is aware.
My opinion is this SingleFile extension and codebase are what they should be emulating. It captures the currently rendered page (so if you scroll all the way down, it will capture everything that pops into view, and anything else that JavaScript changes.)
thanks, just used SingleFile, this is the screenshot. I guess this is an extreme example that no app can handle that, I think Singlefile should have no issue on other less problematic sites.
If you are clipping to read later, Instapaper is hard to beat. If you want to read later and have the option to export to markdown, html, or pdf try Notion.so
I played around with Singlefile more on other sites, works quite well.
Now my new work flow is to download the html file locally , then open that on Bear Notes to read. Bear Notes seems to the best reading app on iPad. I could have save that to DT3 and let it sync to DTTG to read on iPad but somehow the sync between DT3 and DTTG is not as smooth
Next step is to try to automate this with Shortcut or KM.
Thanks to @cornchip to introduce me to this brilliiant Chrome extension
