Does anyone have experience with either of these two brands for temperature sensors? I have an Ecobee and sensors for the house for Heat/AC.
I plan on putting (either Eve or Aqara) in both my garages. I plan on doing some work in there with lasers, engraving, etc. I figured a sensor in each would be good, if it proves useful, perhaps I can get some for the house and tie into an automation or something.
What i heard in the last MPU-podcast #573 from Rose, Aqara is “cheap” and works good for her. And you will need the newer hub, with HomeKit-support.
Aqara Temerature - 19€ + 70€ for the hub. Will be “cheaper” with more than one sensor.
I have Aqara and Netatmo. I’d recommend Aqara, because it uses its own network (zigbee) instead of WiFi and Bluetooth. Plus you can use the hub for lots of other sensors - like a door sensor, or a vibration sensor (on your office chair ).
