In Episode 471 David has talked about a shortcut he is using to enter appointments in Fantastical - Control Option Command F to speed things up. I am interested in that, can you elaborate a little more…
In the Fantastical preferences you can set a keyboard shortcut that will open the menu bar app with the cursor in the appointment entry field so you can just start typing. Just go to preferences in the Fantastical app and it’s down at the bottom of the General tab.
Thanks a lot Chris, that was easy…
