Response I’ve gotten there is “CleanMyMac is the problem - clean install is the only answer” - even though FCPX starts in guest mode, and I haven’t run CMM recently.
Any suggestions for my problem, and what are community thoughts here on Clean My Mac? I’ve used it for years without problems.
If it starts in a guest account, the issue is probably in your user folder. You can find it’s preference files in ~/Library, move them to your Desktop and see if it starts. If it does, you can test each file until you find the culprit.
May also be a cache, library or app support folder, all in your user folder.
VM Regions Near 0xfffffffffffc7e00:
–> shared memory 00007ffffffeb000-00007ffffffec000 [ 4K] r-x/r-x SM=SHM
Application Specific Information:
dyld: in dlopen()
/Applications/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/MediaProviders/FxPlugProvider.fxp/Contents/MacOS/FxPlugProvider
