features? Any downsides? Thanks?
I did, and then has to disable it. It prevented Pi-Hole from working on my network by adding a DNS before it that wouldnāt resolve. Itās a nice feature, but until they fix that bug Iām happy to live without it.
I did not. I run Eero in bridge mode because I want to preserve the WiFi networks that my router generates.
I did, and it needs little intervention from the user.
In theory itās segregating each IOT device from the rest of your personal devices. So for devices that donāt use a hub which communicates over WiFi or that only talk back to their makerās website, a breach in security should not affect your other devices.
Iāve not had any negative experiences.
Same for me. 20 characters ā¦
Just interested in why youāre doing that. Do you have multiple WiFi LANs for different devices?
I use Eeroās standard Wifi network for own devices and guests go on the Eero Guest Wifi.
Hmm I got my eero in April and we havenāt had a guest in the house since⦠#pandemic-tech
Strange topology preferences mainly.
It gives me four wireless networks that have different purposes. Plus, I have an equal distribution of wired (ethernet) and wireless devices and prefer to manage everything at my fibre router. The eero is just another device for convenience purposes to haul the signals across the house. The routerās networks do not reach the farthest corners; the eeroās networks do.
I think itās worth setting up.
It gives two advantages:
- You can restrict communication for less trustworthy products (Iām looking at you, Aqara)
- You donāt expose your WiFi credentials to vendors. Instead, a unique pre-shared key is generated (but requires you to re-add the device)
Most people say that they donāt care if a vendor knows whether their lights are āonā or āoffā, and while I do care about that, I mainly worried about the cameras I just began to add. The ālocalnessā of HomeKit is partially why I chose it in the first place.
The main downside is that accessory firmware updates donāt work when set to ārestrictā, but those come out so infrequently that I donāt mind.
I ran in to the same issue as @RosemaryOrchard with my Pi-Hole, but ended up buying Eeroās Secure product because cloudflared kept having issues on my Pi-Hole. Eeroās ad-blocking is in beta still and honestly isnāt very good, but itās fairly cheap to get encrypted DNS without all the hassle of maintaining yet another thing (though Iām a nerd so maybe Iāll miss that
