Looks promising. I may give it a go when I have some time.
Folks should be aware:
MacOS
MacOS has unofficial support provided by the community. The app mostly works but for a few quirks. Unfortunately, you will have to compile the source in order to run it, as there is currently no installer available.
Download the source code from the GitLab repository and see the README.md file for build instructions.
If you would like to contribute to improving MacOS support, please see the contributing guidelines.
I know, building from source is a bit of a challenge sometimes. I built it some time ago and it did work, so have been using it off and on for a few weeks. (mainly as I also use it on my linux machines)
