My imac is on its last os upgrade as it won’t run Ventura. I’m currently on Big Sur on a late 2015 imac 27". One app I need on is Monterey at a minimum, so it’s time to upgrade.
Do I just upgrade as is or wipe and clean install?
When was your last clean install?
Some recommend to do a clean install every 2nd or 3rd upgrade.
I clean installed Big Sur
Go for it. just upgrade. Should be no problem
