Just a quick report. I ordered a Function remote for the Apple TV (based off a design available in Europe but not previously in the States). It arrived, after being on back order for about a month, today.
No setup was required. It turned on the Apple TV automatically. It’s an infrared remote so it needs a clear view of the front of the TV itself, but that wasn’t a problem the way I have things set up.
This thing is revelatory. I really dislike the remote that comes with the most recent Apple TV. Fiddly and small, it doesn’t fit my hand at all. No idea what Apple was thinking when they designed it. But the Function? Ah. Fit’s my hand properly, has a straightforward rocker switch navigation pad and is easily paired to the TV itself to handle volume, etc.
This is the remote that should have been in the box. The Apple TV is just so much easier to use and manage with this thing.
Thanks @wnknisely and @ryanjamurphy for the review and the info. I rarely use my Apple TV because I absolutely hate the Siri remote - and haven’t found a suitable 3rd party remote.
I read about what appears to be this same remote some time ago. A cable provider in Switzerland started using Apple TVs as their standard cable box, but their customers didn’t like the Siri remote. So they had to replace them with a button style remote that looks identical to the Function. Unfortunately they didn’t sell them to non-subscribers.
FWIW, the old-style infrared Apple remotes work with the Apple TV.
Obviously, they don’t have the swipe pad or the volume control.
I like the Siri remote. It could be bigger, and it could also be cheaper to replace.
