Any Gimbal (or similar tool) suggestions? I’m finding an interest in taking more video, and would like to take things to the next level.
I know pricing can range for video tools. Given that, I’d welcome a budget and mid-range option if possible?
One thing to check on is how well it holds the phone if you want it in a case. I have the OM4 for my iPhone 12 Pro, and was disappointed that the gimbal was designed for the rounded edges of the prior iPhone. It would work with a case for the older iPhone, but wouldn’t hold the new one securely unless naked. I ended up hacking together a solution involving a piece of metal and the MagSafe connection on my Apple case so I wouldn’t have to take off the case to use the gimbal.
(I have no idea if the new OM5 has the same issue or not, but it is worth checking)
Thank you both! The OM5 looks like the right tool for what I need. I’ll look further into if the case is an issue with the newest design.
I have the Osmo Mobile 3. Great tool for video, DJI software for it is also nice.
