I’m looking for good options for USB-C to USB-C cables that support USB 3 for purposes of getting the maximum data transfer rates with my iPhone 16 Pro.
I typically use Anker cables, which have always been reliable for me, but I’m not sure if they offer any good options with these requirements.
They do offer some USB 3 cables, you just have to make sure you get the right one! I know they do, as when I had a Meta Quest headset, I needed a fast USB 3 cable to hook it up to the PC and the online recommendations were for an Anker cable, rather than the massively overpriced Meta one!
However, checking Amazon history, that was a type A to C cable (Powerline+).
Checking the Anker website, the Anker 515 USB-C to USB-C Cable is a USB4 cable and will get you the fast data speeds.
