I open a lot of tabs by long-pressing on a link on a website and then open in a new tab. This has been so fast since - always . Just a long press and then one tab with a finger on “Open link in a new tab”.
In iPadOs this has changed. It’s no longer as fast as all. Is this annoying to anyone else as well?
I find that using a two-finger tap to open links in a new tab is preferable. It’s faster and works well regardless of how the tap-and-hold mechanism evolves over time.
I realized that when it misfires for me, it’s because I didn’t have my two fingers close enough together. I guess it was registering them as two separate taps instead of a single two-finger tap.
In any case, if I make sure my fingers are actually squeezed together when doing the tap, it seems to work pretty much flawlessly.
I have this same anatomical challenge and while it never presented itself in the case of this two-finger-tap dance (which I never knew of; I always long pressed, too), I have experienced it when trying turn my iPad software keyboard into a trackpad using the two-finger tap.** If the keyboard registers your fingers separately, it thinks you are trying to do text-selection instead of cursor movement.
I had this same issue at first, but then I realized that “open in a new tab” came up as the first option in my context menu. So it does not seem to be taking me longer than it used to.
I always have a lot of tabs open in Safari on my iPad running iPadOS.
But I often experience that my tabs disappear when I open a new window on iPadOS, through slide-in or private safari tabs. Then I can’t find those tabs again, but I can see that they’re still available on my iPad through iCloud Safari tabs on iPhone (see screenshot).
Can anyone explain why this happens and what I can do to prevent it?
When they disappear on iPadOS then I have to go on my iPhone and find the open tabs and pull the tabs into my iPhone and then again pull them from my iPhone into my iPad. If that makes sense at all.
I will try and do that next time, this problem appears. I assume that action will take other Safari windows that might be open and merge them in the currently open window. That should solve the issue
