Thank you for all the responsesâŚand yes an open to the idea that it may be my understanding of the technology that needs tweaking.
TLDR - something in my setup isnât working right to replicate functionality of iCloud.
Speeds - donât mind slower speeds as the priority is to get the setup working like iCloud, even if it would slow.
Resilio Sync - loving it for years and use daily. I use it mainly to get files around automatically. These directories are sectioned off on each device, and from time-to-time I organize files into a different, more permanent, location. (note - be wary of the âRemove all synced filesâ option as this is prone to error.) Do not want Resilio Sync having access to all the data, which is the reason I have RS directories sectioned offâŚand it handles ârecentsâ so-to-speak, and on occasion I throw in files that could be handy to grab while away.
Side note - there is a RS client for Synology as well (albeit I havenât gotten it complete working yet, project for another time.)
Synology Setup - SMB has been the protocol along w/Webdav. From the Mac, mount the shared volume and it sits in the finder left bar. Everything seems to work well except:
- saving always gives a warning as permanent (saving versions not supported and such)
- any type of modification (including delete) are permanent. No trash can. No undo etc.
- apps that support iCloud donât support Synology in the same ways (maybe it is my setup?)
iOS - From iOS devices Iâm using FileBrowserPro (OwlFiles also worksâŚeven Transmit) to access Synology files. *Synology Drive, itself, seemed a bit too rudimentaryâŚnot enough TLC in the UI and experience. *
Note - only FileBrowserPro shows in the various iOS âshareâ menus.
I can âaccessâ files stored on the synology as needed ⌠as a file server. Working from a file stored on the synology is the hiccup. Apps that support iCloud so you can work from any device off the same datafile, is what is happening.
Testing right now⌠I can access everything fine using FileBrowserPro etc. I create a new Pages document from the iPhone and hunting for a spot it will allow me to save and switch over the Mac (replicating iCloud experience.) Pages is allowing me to âcopyâ but not save original. If the âhome cloudâ so-to-speak were working, it would be as seamless as iCloud.
Switch over the Mac, open the test document and edit. Upon save " The document âContemporary Report.pagesâ is on a volume that does not support permanent version storage.
Save it anyway, return to iPhone and test document not updated because I edited a copy, not original.
Next, I am in PagesâŚneed to browse to freshly edited document (this time I use Owl Files to get it.) Open, I am seeing the edit. Go back to Mac, open w/pages and most recent edit is reflected.
