So, Hazel 5 is out. However, when I try to install it I get:
Anyone else seeing this?
Installed fine for me. I did not have an old version of Hazel on this computer when I installed v5. I’m running Hazel 5 in trial mode on my MacBook Air with current version of Big Sur.
My updated failed as well.
Update worked fine for me. Suggest you contact the developer.
I didn’t have any issues, but I downloaded the upgrade from the link they provided in their email announcement not directly from the site, and I was also already running the beta.
Worked for me installing over the top of the old version.
Hazel 5 installed OK, but the noodlesoft store won’t load.
I had issues trying to do the in app update from rc2 to 5.0, downloading from the site worked fine.
right click -> select “open” did not allow you to open the app?
No problem on my end (downloaded the trial version, installed over v4, bought upgrade pricing). Running Catalina latest version.
Same here. The noodlesoft store finally allowed me to purchase an upgrade.
After a couple of emails with the developer, he thinks it’s a Mojave issue:
I think it’s a bug in Mojave. The app is signed and notarized and the problem isn’t occurring on any other supported os version.
Thanks for the heads-up, I’ll wait till it gets resolved.
What features are y’all looking forward to?
I like that it’s a separate app. The old interface always felt kind of cramped. Other than that, I’m just happy it’s 100% compatible with Catalina and Big Sur. Hazel is one of those apps I love and will keep updating but I’m far from using its whole range of features
We’re the same. I’ve only used most of the built-in rules asides from having Yoink pull any screenshot I make. Happy to pay for the upgrade too.
What he said. And almost every single time I am modifying rules I click the wrong search box - the one that searches all of System Preferences. That won’t happen any more!
Also looking forward to seeing how I can use the lists feature. Looking forward to the @MacSparky video hopefully there is one in the works??
