I’m hoping some of you can give me some direction in how to configure my next Mac.
I currently use a MacBook Pro 16" 2.3 GHz 8-Core Intel Core i9. 16 GB memory. Intel UHD Graphics 630 1536 MB (I don’t know what any of that means, I just copied it LOL).
Most of the time, my MacBook stays docked to a CalDigit dock and powers an old school Apple Cinema Display and an LG 38" ultrawide monitor. I occasionally take the MacBook into court/depositions/remote work sites but a majority of the time, it stays connected to the 2 monitors.
I am in the habit of leaving open apps and windows all the time as I it’s a pain to keep opening and closing apps and I frequently move back and forth between apps.
Apps that pretty much remain open all day - Word, Pages, Excel, Safari, DevonThink, Fantastical, OmniFocus, OmniOutliner, Obsidian, Spotify, Drafts, Acrobat and Mail.
I don’t get too crazy with an excessive amount of Safari tabs open at the same time - at most 10.
Here’s what I don’t like about and/or concerns me about my setup - I’ve been using DevonThink (indexed files) more lately and there’s a lag especially when I’m using the find/search feature in the upper right corner or when I’ve just used the “move” command to move files from the inbox to a specific group - the lag comes as I type the desired group after evoking the keyboard shortcut to move file. I’m uncertain if it’s because I don’t have enough RAM/processing power or if that’s just how DThink works. I don’t see a lag anywhere else.
Also, it seems like the fan on my MacBook is on a lot of the day - not so when I’m working without it being connected to the dock.
I’m also concerned about battery health (should I be?) because the majority of time, the MacBook is plugged into the dock and power.
So, I THINK some sort of M1 MacBook would work for me but not sure as to what processor and how much RAM I should get. Maybe even a Mac mini in conjunction with my existing MacBook?
I’d be very interested in seeing what the community thinks about what I should do.
Thanks!
