Help: task management
Now don’t knock me over, but I am swithering (yes, it’s a word) about my task management system. I’ve been in Omnifocus for years (thanks MacSparky) but find it overwhelming, I own Things 3, & I’m playing with an obsidian/claude only and a claude/todoist (these two running in parallel at the moment which is eating tokens).
I want:
  • the most important thing is not to be overwhelmed. I work what is effectively full time as a locum GP. That’s not what’s in my task manager/claude - except the organisational side. I have a lot of stuff with home/play/work stuff. I find it really hard to settle without checking everything else.
  • to be able to check off tasks visually on my phone
  • to use claude to surface what needs to be done in a timely manner & to run reviews & generally organise the system. (but not do his own thing)
What are you running?
How do you integrate Claude with your to-do system?
Not after your perfect solution, but keen to hear what you are doing the pros & cons.
Thank you!
I use the TaskNotes plugin inside Obsidian and as mentioned in another thread,
TaskForge works with TaskNotes or the more common Obsidian Tasks app.
TaskNotes is a note-per-task system so like MacSparky’s RAFG system but more sophisticated (eg recurring tasks). Claude can read and write my TaskNotes, there is a MCP but I don’t use it.
I also use Due on my phone for reminders and TickTick for a lot of recurring stuff that I don’t need to clutter my vault with and certainly doesn’t need Claude’s involvement.
Used Omnifocus for years, then used Todoist for a couple of years. I have settled on Reminders. Few more clicks but does what I want, syncs with BusyCal. Everyone’s needs differ.
Another recovering OmniFocus addict. Some days I spent more time futzing (a type of swithering) with OF to make it just so. Then I watched Sparky’s Reminders Field Guide (part of the Productivity Suite Field Guide), and immediately went cold turkey on OF. It’s been more than a year, and I’ve never looked back.
Does what @Tatters wants. The path for Claude to see the reminders is via the Fantastical MCP. My key Reminders list syncs with Fantastical.
Obsidian and the Tasks Plug-in
I’ve listened to MacSparky’s reason why not to use that plug-in (single major developer etc. etc. etc.) BUT I also have forked it and it is the one thing that handles my rather complex way of working.
I have several catch-all notes that collect tasks in a general way. For projects I use a base project note that gathers all tasks related to that project, and other info in one place so I can easily switch to working by project vs by context as necessary. Often when a project has project specific files I gather them into a folder. When the project is completed the note (or the whole folder) goes into my archive folder so I don’t lose the history. I tag tasks with context (GTD style) and have a curated set of nested tags that do that for me. I require keeping a history of finished tasks with their finished date.
I have available projects/tasks that I swap on a quarterly basis so I always have a LOT more things that I could be working on than I can actually do in any given day week and sometimes even season. But it works for me. I typically have around 400 individual concrete doable tasks available to me and am typically running with about 100 projects usually about half one-off and half recurring multi-task things I do regularly.
I work on my iPhone from my Dashboard note that has all my available tasks with a nice clean checkbox to mark them done sorted by context.
I do not currently use Claude to integrate with it at all. I want to stay in charge of my projects and tasks. However, I do now have a context for Claude of individual tasks where I can use Claude to help me finish it. So for your last item I can’t help at all.
