Ok, Exploring moving from interactive ChatGPT sessions to using Devonthink as my primary AI interface.
I understand that I will need to get an API key from the LLM provider of choice (ChatGPT) and from what I have determined, that is billed a la carte for usage, but is also completely independent of my existing paid $20/month ChatGPT plan.
So, if I want to only use API key access, am I correct:
1 - I will have to backup saved chat sessions and ‘projects’ in my current ChatGPT app workspace to external files (which I can later incorporate into my DT files/database)
2 - Cancel my ChatGPT monthly account
3 - For interative, casual chatting, I would have to do that inside Devonthink using the DT Chat Inspector and DT Chat popover (if I want to keep archive/history of my sessions as I do now)?
4 - If using the web directly, or the ChatGPT macOS app, I would be using the free versions that don’t keep memory or history of my sessions?
5 - Lastly, how would I use ChatGPT from an iOS device? Does DT have a “Chat Inspector” as part of DevonThinkToGo or as a standalone app for iOS?
(I do plan to consider other LLM’s in addition, or in place of ChatGPT, but think replicating my current setup to use ChatGPT and API tokens inside DT is my first step to changing my AI workflow to benefit from DT’s support for AI work before going on a side-quest of comparing various LLM’s or even running a model locally.)
Open to any and all suggestions, including not using DT, but I already own/use DT heavily.
I guess I should explicitly say - my primary goal is to eliminate the friction in merging LLM output into some of my existing writing-heavy projects in DT. Keeping track of multiple branches of exploration, and avoiding all the formatting problems I’ve been having by manually cut & paste I am doing currently.
Have no interest, at this time, in using DT for image generation/editing, or any video/audio manipulation via AI. (Have those covered in other tools)
