Hoping there is someone in the chat that can help me with an annoying problem. I set up a web audio stream in Audiohighjack pro. When I do an actual recording, from what I’m hearing it sounds like my voice is echoing, but when I go to the playback it sounds fine (no echo). Its not a dealbreaker but it is annoying.
I have the Source to Include audio input. An online note that I found said to decrease the Audio Processing Latency in Preferences, but that did not help.
Near as I can tell, I think it has something to do with Output Device, but I’m not sure.
Can someone with experience with audio highjack give me some advice.
Here’s a screenshot of one of my session setups I use for both recording and broadcasting. As you can see, the main audio goes to my output — in my case, wired headphones connected to output from my Blue Yeti mic — and that is what I hear in my ears when I’m live. The mic input is then fed into an auto-ducking block along with the output, and the combined result goes to the recording and broadcast block. (The Peak/RMS is optional, but I like to see it in my menu bar.)
Theoretically, yes, but the reality is that it would greatly reduce my freedom of movement if I did that — I’d need to get headphones with a much longer cord for that to be practical.
I used to have the input and output set directly in Audio Hijack, the only catch is that if — as has happened a few times — I change to a different set of headphones, I then have to remember to change those settings across multiple sessions in AHJ.
One thing I love about SoundSource is that it gives me a full overview of what my audio settings are, and in particular whether any are muted!
