I’m trying to create a shortcut to add multiple tasks to an OmniFocus project but can’t get the text to split into separate tasks.
Can anybody point me in the right direction? Thanks
Put your OF add task inside the repeat loop and use the repeat variable (you have to know to type it; it’s not obvious.)
Thank you very much!
I’d I’m already pushing my luck, Is there a way I can send them all at once if they’re all going to the same project?
No problem! You can do that with the Taskpaper format and shortcuts action.
On any project or selection of tasks, you can right-click and Copy as Taskpaper to see how the format works with your existing data.
https://support.omnigroup.com/omnifocus-taskpaper-reference/
Edit: the shortcut in that screenshot is Add Taskpaper
Once again- thank you ![]()
