I have a Canon Pixma iP4700 - works fine but family is demanding AirPrint and after using an AirPrint printer recently I’m inclined to agree. I tried using the trial of Printopia to share from my Mac with no success. I’d still prefer a software solution to a new printer. Any suggestions?
Thinking this through - is there a way to accomplish this by saving a PDF to the Mac and having Hazel do the printing?
With Printopia I went through all the troubleshooting and it would never print - ios devices recognized the printer but always failed to print, with a nondescript error message.
I have an always on Mac available for Hazel, where I can connect the printer.
AirPrint is the better solution. It is so frictionless and lets you control options like plain paper vs photo paper, double sided and so on. I don’t think you can get that with Hazel.
I agree with this. Get a new Airprint-capable Printer. The iP-4700 is a photoprinter anyway. Are you printing mostly photos, or are you doing documents too?
One could presumably have Hazel watch particular cloud-synced folder, and have it act on files with matching criteria (Kind is PDF; Tag is Print) or some such.
Haven’t really looked at Hazel’s implementation into the system - but come to think of it, KM could probably do this as well, and it would give you more “in’s” at system level.
I was toying with same idea - but haven’t gone down the rabbit hole until I get my printer onto a network.
I’ve used Printer Pro by Readdle for years. I have an old HP LaserJet that is on my network but does not have wifi. I run Printer Pro Desktop on my Mac Mini that is always on, but I can’t remember if I still need to do this.
Printing is a little odd with Printer Pro; essentially, you send the thing to be printed to the Printer Pro app on your phone through the action menu (formerly called the share sheet). That can make printing from some apps difficult or impossible. For example, until we were able to make a pdf from an email, you couldn’t print an email message.
It also hasn’t been updated in a while. But I just tested it, and it worked fine on my iPhone XS.
Well I took the easy route and got a new Canon TP8520. Haven’t tested to see how photo quality compares to the ip4700 yet but otherwise it works wonderfully with minimal setup.
