Home Screens in focus modes on iOS16
Hi, there I started using focus modes with iOS 16. I found that I can create my own focus beside the ones that are preconfigured.
But on that own ones I can not create exclusive home screens that are hidden in other focus. Is that normal/is there a work around for that?
BE
Jackal
EDIT: See @geoffaire 's post below… I was wrong about this.
Each focus can select which home screens are visible. It’s not possible to have a home screen that is only visible in one focus mode. Turn focus mode off and they’re all visible.
I’m hoping Apple develop the Focus modes - it would be even better to be able to limit the device to specific apps while in focus mode… as it is, swipe right and all the apps are there whether on the home screen or not.
You can choose for each focus mode which home screens are available from settings / Focus / choose focus / choose edit under customise screen (middle screen)
Where you do not select a focus mode, as default it will show all home screens, but if you go into Jiggle mode (while no focus mode is selected) and then tap on the dots at the bottom (above the dock) you can choose which screens show in default (no focus) mode.
This is not true. Have a look at my instructions above.
I stand corrected! That’s pretty neat… although in my defence perhaps illustrative of the increasing complexity of the iOS UI.
That is amazing I didn’t know that is possible to access that menu via the dots! Thank you very much! :+1:
