You should have Claude Desktop installed on the Laptop and logged into the same account as the Mac Studio. Then you should be able to see the Dispatch folder but it should be in sync with your MacStudio. I currently have 2 laptops and thats what l do.
Unless l am missing something, OR you could ask your robot to help you.
I’ve never seen that screen/error and l have connected from my iPad and iPhone.
So what exactly are you trying to do? You have Cowork desktop on the Studio and the laptop. Then you are trying to access from 2 mobile/dispatch devices?
Thx Sue. I’ve got cowork dispatch running on my macstudio. I can connect from my iPhone and iPad, very nicely. But the MacBook Pro only allows me to run a new dispatch session; it doesn’t let me connect to the one on the MacStudio.
I am very sure this is a (current) limitation from Anthropic.
An ongoing dispatch session is only accessible from mobile devices, and not other computers.
(I have the same «issue» as you)
A suggestion could be to set up a Claude Code sesssion and use channels, this would allow you to access Claude Code through either Telegram or iMessage.
If you use claude code, you can use tmux (brew install) to connect to it with a terminal app such as termius while on your network. For outside connections there is of course poking a hole in router (port forwarding) and ssh but not the best for security. Better: cloudflare tunnel, ngrok…
