One of my main complaints about Safari is that you cannot easily switch to an existing profile window. That is, you can create new Safari windows with a specific profile with a shortcut or with the UI selector, but you can only switch to another profile if the current safari Window has not tabs.
I’ll explain the best solution I’ve found here.
The first solution is a nifty helper tool called ProfileLauncher (one time payment, $5):
As can be seen, the app recognizes all of possible Safari profiles through a smart accessibility hack and gives you shortcuts or even app urls to switch to those windows. You can even add these profiles to the menubar. Easy!
But sadly it doesn’t offer good keyboard shortcut support and also you cannot select which of the profiles are shown in the menu (you can see I have quite a few for personal and work stuff)
In ProfileLauncher the shortcuts to open specific Safari profile windows can be turned into mini-apps that perform the action, which you can potentially add to your launcher of choice, or even keep them in the Dock.
Now please enter Folder Peek by the profilic Sindre (free).
What I did was simply create a specific folder where I put there the mini-launchers created by Profile Launcher but only those that are my most used ones. And then it’s simply a matter of creating a menu with Folder Peek, assigning it to a hotkey and I’m golden, I now hit OPT-A and bam! instant profile switching in Safari.
As an added trick, I renamed the profile mini launcher apps so that they are numbered, so Folder Peek allows me to select the right option with a number.
Edit to add: why do I have that many Safari Profiles? The answer is being a consultant that has to work with a bunch of different Teams tenants associated with the same work email address so I need to have strict cookie isolation in the different Microsoft domains otherwise Teams ends up misbehaving. Also, each Safari profile can keep its own Bookmarks bar, which is very useful and quick to manage relevant reference bookmarks.
