I need to set up a way to print from my iPad at work.
The printer is on the network at my work address and all I have is an IP address.
Does anyone know how to set that up?
I’ve had good luck with Printer Pro:
I second Printer Pro.
I recommend the “try before you buy” option for Readdle Printer Pro. I never got it working on my system.
Do you know the brand and model of the work printer? A lot of printer vendors have iOS apps that can do this for you.
Hmm interesting. I don’t actually. I would have to check on Monday or Tuesday, when I have time. I will report back. Thanks a lot! This would save me a major hazzle of having to download all my iCloud files to a work PC
One other thing to try if necessary at the office. Use a browser to visit the IP address of the printer. Modern printers will often display a list of tools and other information.
Sorry to revive this old topic.
I had success with Printer Pro by Readdle in the past, but they are no longer making this app. Is there a current one that people like to print from iPad/iPhone to a printer via IP address?
Thanks.
An App Store search using:
print from iPad
resulted in several apps, including some from printer manufacturers.
Good luck
Thanks. There were quite a few. I was wondering if there were some that were regarded better/best among the group. Happy Holidays.
I print often from both my iOS devices to a networked Brother and a Cannon printer without any add-on apps.
If the printer is AirPrint enabled and connected to the same network you can print directly from a Mac, iPad or iPhone.
Get an AirPrint printer, this solves it. Otherwise, usually the printer company makes software that might be available on iOS as well
There are devices available that can be added to a wired network that allows wireless printing to Ethernet only printers. But for the price of some of these devices ($100 or less) you can also purchase a Brother laser printer like one I’ve owned for years.
On those rare occasions that I actually need a hardcopy, I print to it wirelessly from my iPhone, iPad or Mac. ![]()
Thanks for all the replies. I want to print some teaching materials at work. We have HP network printers scattered around the department so I can’t buy any new ones. AirPrint with a Brother works great at home. The ones at work have IP address I can get, though.
Could you create, then email, a PDF of your teaching materials from your iPad to your work computer and print from that?
If there’s a mac at work you can install Printopia on, as that will enable air print from your iPad.
