If the Samsung T7 is anything like my Crucial X8 then I don’t think you’ll be able to get a SMART reading for it. The Crucial X8 uses an NVMe drive internally and it looks like yours does too.
Whether or not NVMe SSDs have SMART attributes depends on your perspective. In the perspective of the NVMe specifications, a NVMe SSD is required to provide you with what is called ‘SMART / Health Information’, so maybe you could say it has SMART attributes. In practice, this information is not in the format of SMART attributes and it doesn’t have the fields that they do, not even so much as an ID number.
So I doubt conventional SMART monitoring utilities will be able to read data off of it.
It points back to DriveDX, where there is an Apple Silicon version (SAT SMART Driver for Apple Silicon Macs) but it is not clear if it is still a kernel extension.
Looks like the issue is based in both the hardware and the OS.
DriveDx won’t do the trick either way. Unless you like being spooked by faulty readings.
Samsung Portable SSD T7 / T7 Touch is NVMe-based SSD internally, so it is not compatible with SAT SMART Driver. SAT is shortened for “SCSI to (S)ATA Translation”, it is for SATA-drives, not NVMe/PCI-drives. For more information about NVMe SMART over USB – please check this article in our FAQ.
Currently, there is no NVMe SMART over USB drivers for macOS. macOS does not support this and there are no third-party drivers (kernel extensions). Moreover, currently, there is no official specification for NVMe SMART over USB from NVM Express Workgroup. Currently only vendor-specific workarounds available like JMicron and AMedia but there is no common standard.
Some examples of external USB SSDs that are internally based on NVMe SSDs: Samsung Portable T7 SSD, Samsung Portable T7 Touch SSD, Crucial X8 Portable SSD, Sandisk Extreme SSD, Sandisk Extreme Pro SSD.
