How to use "unsupported" 2560x1440 mode of Dell monitor without 3rd-party software?
Unfortunately macOS does not support the native 2560x1440 resolution of my Dell U2711 monitor (it uses ugly scaled 1920x1200 instead). On my personal MacBook Air M1 I work around this using SwitchResX. However, I temporarily need to (also) work on a MacBook Pro M3 from work with the same monitor and I am not allowed to install any 3rd-party software on that machine.
How can I still use this “unsupported” 2560x1440 mode without 3rd-party software?
My hope was that I could just copy the DisplayProductID-a055 EDID override file that SwitchResX put in /Library/Displays/Contents/Resources/Overrides/DisplayVendorID-10ac between the machines, but that does not seem to work.
What might work?
Something feels very odd to me about this problem. I had a similar monitor (old Dell 27" @ 1440p) and my M1 Pro machine never had issues outputting to the native panel resolution without extra software. My first thought would be to check the cable being used. If it’s a USB-C to C cable, make sure it’s actually rated for the full speeds and not a charging cable with a 480 mbps data rate. I can’t test again unfortunately but that would be my first guess
My M1 MBP Pro is outputting to a Dell U2715 at 2560 x 1440 resolution on the Dell. No issues at all.
The MBP is connected to a dock which is connected to the monitor via DisplayPort.
I recall with my monitor when I upgraded to the M1 MBP, the advice at the time was that DisplayPort provided a more reliable connection than HDMI.
You might want to investigate whether your monitor has a DisplayPort output which you can then use with a DisplayPort to USBC cable.
The monitor is rather old (from 2010-ish?) and has no USB-C input. It does have DVI (2x), HDMI, DisplayPort and VGA inputs. Unfortunately the monitor limits HDMI to 1920x1080, because it runs in some kind of “TV mode” on that specific input.
I have two USB-C dongles that I can use and two different cables: HDMI (dongle) to DVI (monitor) and DisplayPort (dongle) to DVI (monitor). All combinations of dongles/cables can drive 2560x1440 with SwitchResX on my Air, but only 1920x1200 without it.
In the past (still an Intel Mac instead of Apple Silicon) I also used a USB-C to DVI cable (without a dongle), but that cable broke and also needed SwitchResX (or at least an EDID override) to run 2560x1440.
Oh, the dongle I got from work (one of the two mentioned above) also has a DVI output. I tried the dual-link DVI cable that I (successfully) use to drive 2560x1440 on my Windows PC and am again stuck with 1920x1200 on the Mac…
Somehow macOS is limiting what’s possible?
(And I think I used EDID overrides on Intel Macs to work around that, but this does not seem to work on Apple Silicon?)
On the very slight chance that you haven’t already done the thing in this video, I offer up the thing in this video: https://www.youtube.com/watch?v=w7N3PsMvDaI
Yes, I already did that.
1920x1200 is the highest resolution in my list; 2560x1440 is not included (unless I run SwitchResX).
