My Toggl app seems to have completely lost (or just not tracked) several days worth of data, and I’m trying to collate what it thinks I have with several calls that would’ve coincided with the tracked data.
The problem is that my iPhone only goes back a fixed number of calls.
Is there an easy way to get a more extensive call history list? Ideally in a Mac app, so I don’t have to mess with it on my phone screen?
Can you get it from your Telco?
Maybe, but not easily from what I can tell.
I think the iPhone itself only shows the last 100 calls.
I’m not aware of a way any Mac (or other) App could do this in the absence of previously-installed and configured profiles for MDM. I don’t think you can add it after the fact and “recover” that historical data.
I’m not sure what carrier you have, but with AT&T it’s quite easy to log in and see a detailed call (and data) history with number, date, time, and duration. (It’s under “See Data, Text, and Call Logs” in the Usage section of the site). I export this to an .xls (.csv also available) when I need to go through it.
I’m on Mint Mobile, and I don’t see a good way to get the data. I was hoping that maybe the iPhone has more than 100 calls in its memory, but it just can’t be accessed through the default UI.
Seems like a very low limit.
Ahh, yes. MVNOs don’t provide them. (We have a Mint line too.)
Yes, I agree that 100 seems low. Unfortunately, I’m not aware of any option (excepting MDM) where you can get at the log. It doesn’t even give you a “per number” history that I can tell (I thought it did, but checking just now it doesn’t look like it?).
Oddly enough, if I delete calls then more show up at the bottom. So it’s there somewhere - just inaccessible, apparently?
Yeah, that I believe. In my memory (a dangerous thing!), you used to be able to go to an individual number or contact and see a history of calls with that person. It wasn’t infinite, but I know (think) it went back further than the 100 you see in the main list.
