iCloud issues with note sync and backup not working, Apple tech support have no clue what to do
Hi all
I hope someone might be able to help please.
I have issues with iCloud.
iCloud backup does not work (backup failed). (I have gone through “troubleshooting” several times with Apple support. Nothing has worked.)
Notes does not sync - if I write a note on the iPhone it stays there, if I go to iCloud.com and write a note there it stays there.
Photos works fine.
Reminders works fine too.
I have googled it and tried the various troubleshooting methods. I even reset the phone and set it up again, no luck.
I have considered abandoning the account and making a new iCloud account (but years worth of purchases etc) and as I am in the UK I will lose ADP.
I have contacted Apple support again but no one seems to want to take ownership of the issue.
I am certain it is an iCloud issue and Apple need to do something their end.
(I previously had a data usage mismatch and other iCloud issues and Apple’s senior engineers fixed it. I think they did something on the server which houses my iCloud account.)
As you can imagine this is really frustrating and has been going on now for around 18-24 months with no resolution in sight.
The tier 1 and tier 2 support tech support people really don’t know and I don’t know why they don’t pass it to the developers/engineers.
Some of the techies are speculating as to the cause and making suggestions which are unreasonable e.g. turn off ADP, make a new ID instead etc.
If anyone has experienced anything similar and resolved it I would be pleased to know.
Apple’s whole iCloud set up is complete rubbish and its shocking that regulators do not make them open up allowing backups to other storage locations e.g. Dropbox etc.
Apple does not allow deleting an alias and then making a new account with it, which I would be open to doing as a last resort as I am sick of dealing with Apple’s support people. All they seem to do nowadays is churn out rubbish (that includes the hardware sadly)…
You don’t say what steps you’ve taken with iCloud support. What have you tried?
Do you only have an iPhone? You’ve mentioned that there are issues with your iPhone. do you have other devices? If you have a MacBook or an iPad, what happens if you create a note on this, does it sync to the iCloud website?
In the end, Apple owns this whole process, but it’s strange that iCloud backup fails but Photos in the cloud (I assume that’s what you mean) works fine.
How much spare space do you have on your iCloud account?
I forget the exact dates, but about a year or more ago I spent months (a call here and there, a screen share here and there, etc.) back and forth with a nice support rep. He couldn’t help me, but he would take the info, pass it to the engineers, they would pass something back, etc.
The issue was Podcasts.app syncing. Shows would just randomly disappear. Episodes would randomly mark as unplayed, leaving me with a station that suddenly had thousands of unplayed episodes. Devices would not stay in sync. My phone might have 10 unplayed episodes, and my MacBook Air might have 35,000.
Nothing they told me ever worked. Eventually, I tried on my own undoing the Apple ID migrating merge thingy (one ID for iCloud and another for purchases). I began having a hunch that perhaps there was something going on with that. I undid the migration/merge thing, and so far it seems, seeeeeems, that things are okay. Now, instead of waking up to 45 shows randomly unfollowed, there are about 5 out of 100 shows I follow that won’t stick. I keep an Apple note of “problem podcast” that I go back in and follow when I need to.
Reminders, notes, files, and photos all seem to sync fine. For me, podcasts follows are the biggest culprit. Occasionally, Safari acts up (reading list takes forever to sync or just never does, deleted bookmarks show back up after I have deleted them).
I’ve sent in feedback on MPU and another on MGG and also ATP asking them to explain in laymen’s terms what is going on with syncing that can make it just not work. I don’t understand what is going on to make a server and my device stay in sync, but I know that it is frustrating when it doesn’t, and nothing has changed on my end.
The problem is that no-one outside Apple knows how syncing works. It’s what is called a “Black Box” system because what happens is not visible to the user and there’s no way to see what’s happening, let alone force a sync manually or stop syncing.
The merge of Apple IDs throws another factor into the mix that is largely unexplained by Apple. They resisted offering the ability to merge IDs or transfer purchases between IDs for years. When it was offered there was a list of exclusions when read like “Who’s on first” it seemed complex and failed for some users who tried.
That’s likely where your complication has come from, and while you say you’ve backed that out, if Apple hasn’t helped you do that, it’s likely the reversal was unsuccessful (hell even if they did help it’s possible it was still unsuccessful.)
There is likely nothing anyone who is in this forum will be able to do to help you sadly.
I assume you’re tried signing out of iCloud on all of your devices rebooting and then signing back in while ensuring all of your devices are definitely using the same ID? It’s a nuclear option but can help with some sync issues
When you say “Backup,” do you mean iCloud Drive?
In the early years of iCloud, I had a lot of issues with it. However, for the past 5+ years, it has worked flawlessly for me.
I had a client about 5–6 years ago who experienced similar problems. I spoke with a senior Apple technician, and he performed some kind of reset on Apple’s end. After that, everything worked as it should.
With that said, you should probably stay persistent and try to reach the right Apple representative. They do have tools and options available on their side.
If you’d rather not go through that process, the first thing I would try is creating a new Apple account and testing whether it works properly. If it does, you can use the merge feature Apple introduced last year (I think).
Good luck!
I will update here next week.
It’s definitely an iCloud issue.
Apple engineer are on the case now. Let’s see.
I used to have this issue with reminders which Apple fixed eventually when it got to the right people.
Apple said to wait for an iOS release which they said will fix the issue.
The troubleshooting I did involved resetting (network settings, all settings) the iPhone, toggling iCloud off and on, wiping the phone and setting it up again etc etc. Nothing worked.
