iCloud Keychain not syncing between iPhone and MacBook Pro
I have all the options turned on for iCloud yet it seems to not sync passwords between my two devices. Any advice except for getting 1password?
I have not a very original advice, but did you try to log off/log in on iCloud?
Have you tried the tips in the apple support article?
If you can’t sync iCloud Keychain with other devices
Make sure that your device is on a Wi-Fi or cellular network. If the connection appears strong, try these steps:
  1. Turn off iCloud Keychain on all devices.
  2. Turn on iCloud Keychain on the device that has the most up-to-date keychain items.
  3. Turn on iCloud Keychain on your other devices. They will be updated with your new iCloud Keychain.
