I’m wondering if there is a way to initiate a Home Automation below a certain temperature (e.g. from Carrot) without buying a HomeKit temperature sensor?
Not from Carrot, but you can use HomeBridge and a weather plugin to get the data into HomeKit, and then you’d need something like the Home+ app or the Eve app to set up the trigger (because HomeKit supports it, but doesn’t let you directly use it). HomeBridge is free - if you have an always on machine. If you don’t then something like a Pi Zero W would be perfect for this, and it’s not very expensive! Though this may end up being a gateway drug into lots of other automations (dummy switches are one of my favourites).
Thanks Rose, I think that if I was going to do all of that, it would be simpler to buy a temperature sensor.
Well HomeBridge can do more than outdoor temperature, it can do all sorts of things - like add Ring doorbells to HomeKit, and more. It depends on the scope of your desire. If you just want the outdoor weather you can grab a Netatmo weather station or something, but that will cost more money than a Pi Zero W and case (I have both, but they’re used differently.)
I’m still trying to figure these out (the what and how)
Maybe something to explain in more detail in one of your blog posts?
I do plan to do a blog post on this, but there was a bug in HomeKit for a while which made some of my use cases break. Fortunately, it seems to be being fixed!
One example is “bedtime”, this is a switch I turn on when I go to bed, and turn off when I wake up (I trigger scenes using a button, and the state of the switch is set). When bedtime is on the motion sensor in my bedroom doesn’t turn on my lights. Sounds simple enough, but with a varied sleep schedule it’s not something that’s super easy to do in another way. It also dims other lights if they turn on - e.g. if I get up to go do something in my office, the hallway light will turn on, but dimly, and only a few of the lights in my office will auto turn on.
