{This post will be updated as I go through the process of installing the Catalina Public Beta.}
Step 1: Downloading the public beta
Curiously, when you install the profile for the Catalina Public Beta, it downloads a 6.45 GB file, but that does not result in you having an “Install Catalina Beta.app” in /Applications/.
I have created a separate APFS “Volume” called “Catalina” that I want to install the beta on, but apparently I have to reboot my MacBook before I can start the install process. I am hoping it will let me choose which volume I want it on, rather than blowing away my Mojave installation, but I have 2 bootable Mojave clones if I really need to revert later.
Back in a bit with more updates…
