I really can’t make up my mind… I want to replace my iPad Air 2 but I would like your suggestion here: should I buy the iPad Air 3 (64 gb) or the iPad 7 (128 gb)? Both are around the same price here in Brazil.
I do my “serious” work on a MacBook Air, so I don’t think and iPad Pro makes sense for me. I will use the iPad to watch movies and TV shows, read the news and social media, play some games, and annotate pdf’s.
I have the iPad 7th generation, and it’s really a bang for the buck. The 128gb model is definitely worth it. It might have a slightly smaller screen, and the besels are a bit bigger, but at the end of the day, I think it’s your best option. I actually made a review for it on my youtube channel, Mac My Life Up, so if you want to hear about it in a bit more detail, I’d go there.
I can easily see the difference between the bonded vs non-bonded screens when reading text… and I read a lot of text. so if you’re mostly consuming photos and video the regular iPad is a better and more affordable choice, otherwise I’d lean towards the Air.
All current-gen iPads including the 7th-gen iPad can use a Pencil (1st or 2nd gen, depending on the line).
Since the less expensive iPad screen is not laminated to the glass there will be a noticeable air gap between the glass and the screen. Also, because the base iPad doesn’t have anti-reflective coating you’ll likely see a lot more of your own face and other reflections.
Pricing for all sorts of electronics like Apple hardware, Playstations etc are expensive in Brazil largely because they are hit with numerous taxes to an extent not ordinarily seen elsewhere. There are import taxes, ICMS-ST (Substituição Tributária) and MVA taxes, ICMS State taxes, PIS (Program of Social Integration) and COFINS (Contribution for the Financing of Social Security) taxes, and the IPI Industrial Product tax.
I’ve imported inexpensive artwork from Brazil and got hit with outrageous taxes on the way out, too. Even Big Macs are expensive!
