I just wanted to validate something for myself that I wasn’t going crazy (or maybe I am).
When the Magic Keyboard is hooked up to the iPad, for those who charge to the keyboard directly. Does the USB-C fit snugly into the keyboard or does it pop out slightly?
I think that is more a “Standard”, as the USB-C looks similar, if it is plugged in directly to my iPadPro, and it is as with almost all other cable that I can currently observe here from my position, that there is a small gab of a millimetre or so, between the device, and the plug-body.
On a somewhat related note, a few months ago I bought a magnetic USB-C adapter that I leave plugged into my Magic Keyboard. The two biggest upsides are that it saves wear and tear on that USB-C port because the adapter just stays plugged in all the time, and I now have an iPad Pro with DIY magsafe charging. This is the one I bought, in case anyone is interested.
After much testing this week, different outlets, different wires, different adapters. It seems that the usb-c port on the keyboard doesn’t charge anymore. Unless I forcibly push the wire in more it then makes contact and starts charging, but after a while when the wire relaxes, it stops charging. I’ve tried various methods of cleaning the port and nothing seems to work.
