Anyone else have this issue?
Issue 1 - When using Messages, Signal, or really any other that can be used with a Keyboard. It doesn’t work all the time. I spend more time having to close out those apps fully. Re-open them a few times, unseat the iPad from the Smart Keyboard a few times, just to get the keyboard to connect back to a slide over app.
Issue 2 - Frequently, the Keyboard just stops working with the whole iPad Pro. I have to pull the iPad off the connector and then re-seat again.
