IPhone MagSafe minimum voltage or Amps
I’ve bought a MagSafe Puck for my iPhone 12 Pro.
It charges great using the USB C plug from the iPad Pro 12.9”, but when I plug it into my trusty Anker 6 power power hub via a USB C to USB A, it doesn’t charge at all.
If I plug the same USB A to USB C adapter into a 5w iPhone charger with the MagSafe, it shows as charging (albeit I assume more slowly)
Does anyone know what the minimum requirements are?
I think it’s more complex than voltage or current. USB-C has a protocol for negotiating between chargers and devices. Since you’re plugging to USB-A, that negotiation probably doesn’t happen, as USB-A uses a different protocol that isn’t well standardized, and wasn’t part of the USB-A standard.
TL;DR I think the answer is a different charger.
If you want to read more:
A
https://www.electronicdesign.com/technologies/interconnects/article/21801531/introduction-to-usb-power-delivery
C
@JohnAtl is right, USB-A isn’t supported. Read Apple’s Support Document on MagSafe here:
Apple recommends at a minimum a 20W or greater USB-C power source. I just picked up the Apple one for $19.
