I’m going to move 90% of my files over to Icloud, and I thought I would clean it up a bit.
In the home directory of the ICloud drive, there are some folders applications has created. Pages, Numbers, Workflow to name a few. I would like to move all of these to a folder called Apps.
I don’t think it would be a good idea to move these folders since the apps supporting iCloud drive expect these folders to reside at a certain location in iCloud.
It’s not possible on the mac either, I was trying to find a “hidden” way to do it!
@Tonny_Bukdahl I know, and I guess that is the problem. I haven’t looked but I guess then it’s not possible to change the standard location of these documents.
Hey folks - can I confirm what you’ve done here. You create a folder inside iCloud Drive on your Mac (maybe call it ‘App Data’) and then drag the App folders into that new one?
