Hey y’all! Is there a way to force sidecar to recognize an additional computer nearby? Sometimes it’s automagic and other times it’s frustratingly stubborn. Rebooting seems to work but not always and is a pain.
Thanks!
Thanks!
Sidecar was so promising… I gave up on sidecar upon having frequent dropped connections while using it. I don’t know what magic is Apple trying to apply but I guess that the bare minimum to recognise a computer is to be logged into the same iCloud account and the same wifi network, not sure if bluetooth is required.
In giving up, have you come up with an alternative? I only want to share keyboard and mouse. The displays can be the individual computers.
Used the wrong word! Universal control is what I’m trying to activate.
I have not discovered a secret sauce for this. I love Universal Control and use it daily but every couple weeks it barfs. Sometimes just for minutes, more often a couple hours. Eventually it begins working again but I’ve yet to see a pattern.
I assume you do not have a keyboard and-or mouse that can connect to multiple devices, such as the Logitech MX Master 3 mouse? I use it with my work laptop (Windows), my Mac and my iPad. Perhaps updated peripherals are in your future? ![]()
If not, then I’ve used the app Barrier to share a mouse and keyboard with multiple machines. I was pleased with how it worked.
Currently I use Universal Control with my Mac and iPad pretty much daily with no issues. Occasionally it takes a couple of tries to get the mouse from the Mac to the iPad, usually after a reboot, but after that it pretty much just works. Bummer it does not for you.
