Things like screen shots show up faithfully, but files saved by most of the apps I use don’t. Is there a way to make this work better?
Also noting one cannot drag a file from Recents when it is in the Dock
Great question! Following.
I’ve always had a problem with finding recent files on my Mac with all the cryptic names and whatnot. I also can never find any app that fills this space succinctly for me.
I have very mixed results with Trickster. Sometimes it works perfectly, then for weeks it will not work until I uninstall it and reinstall it.
(Yes, it works well for others. I get it.)
Man. I hid Recents from my Finder so long ago I had to rack my brain about what you meant by “Recents”.
Perhaps Default Folder X would be of use?
Instant Recall
To help you quickly return to folders and files you’ve used recently, DFX remembers them for you. It even re-selects the last file you opened. With DFX, you’ll never forget where you put something.
I haven’t played with it much myself. But I had a colleague who used to rave about how easy it made getting to his recent working documents across different apps.
Yes, you’re right, DefaultFolder X does a great job of recents, and it can live in the menubar. Here’s the display there:
To follow up, I bought Trickster, and it’s been working well for me.
Most of the time, recent files, folders, and apps appear in its list. I haven’t done anything to refine what appears and what doesn’t.
There are occasions when a file doesn’t appear, and I suspect it has to do with Apple’s shenanigans to make iCloud Documents, etc. seamless.
