Is there an audio equalizer with presets like SoundSource but with a lower price point?
I recently fell in love with the Sonar parametric EQ feature in the SteelSeries GG app, and I started looking for a similar application for my m4 Macbook. Being able to switch from Music to Movie to Podcast( especially MPU!) presets is my goal here.
The only app I have found is SoundSource, but it is a bit overkill with input and output controls. I just want the equalizer that lets me switch EQ presets fairly quickly.
There is $10 WORLDCUP2026 discount code on SoundSource now, which eases the pain, but if i can the EQ feature for less, then why not?
Any recommendations are welcome, as long as they have the audio EQ feature and are relatively simple to use. No ./configure , make, make install suggestions, please.
There’s also https://litpads.app/litlink but the equalization capability comes in the Pro version (one time payment, 29$). But at the Pro level the app becomes as sophisticated as SoundSource so it’s overkill too.
I don’t have LitLink, but use Soundsource and other Rogue Amoeba apps and can recommend them.
You may try FineTune.https://github.com/ronitsingh10/FineTune.
Its free and has a lot of the capabilities of SoundSource.
I’m going to hold off for now until I have time to do more research. I appreciate the responses.
